Cisco ACI physical interface shutdown via xml file
jchimenop
Hello all
I try to perform a shutdown in the physical interface via xml.
But appear the error Invalid access, MO: l1PhysIf
Checking the information the physical interfaces (l1PhysIf) needs a different config as the other objects.
<?xml version="1.0" encoding="UTF-8"?>
<imdata totalCount="1">
<l1PhysIf dn="topology/pod-1/node-101/sys/phys-[eth1/32]" adminSt="down"/>
</imdata>
Could you help me to do the script?
Can we do that example via XML ?
Which is the correct instrucctions to do that
Thank you
0 Replies 0
