Cisco SFP-10GB-CU3M LRM1919885V availability in India
Devika24
I am seeking information regarding the availability of DAC cables (2 nos.) for the Dell PowerEdge R7625 Server connection to the upstream core switch - Brocade BR-VDX6740-24-F in India. Any assistance or insights you could provide would be greatly appreciated. thank you!
AshSe
Hello @Devika24
To connect your Dell PowerEdge R7625 server to the Brocade BR-VDX6740-24-F switch using DAC (Direct Attach Copper) cables, you need to ensure compatibility in terms of port type, speed, and vendor support. Here’s how you can proceed:
1. Determine Compatibility
  1. Dell PowerEdge R7625: This server typically supports SFP+/SFP28 or QSFP+/QSFP28 ports, depending on the network card installed. Check the specifications of your NIC (Network Interface Card) to confirm the port type and speed (10Gbps, 25Gbps, 40Gbps, or 100Gbps).
  2. Brocade BR-VDX6740-24-F: This switch supports SFP+ (10Gbps) and QSFP+ (40Gbps) ports. Confirm the port type and speed you plan to use for the connection.
Ensure that the DAC cables you choose are compatible with both devices in terms of port type and speed.
2. DAC Cable Options
  1. Dell DAC Cables: Dell offers branded DAC cables that are tested for compatibility with their servers. Look for Dell-certified SFP+ or QSFP+ DAC cables, depending on your requirements.
  2. Brocade DAC Cables: Brocade also offers branded DAC cables. If you prefer Brocade cables, ensure they are compatible with the Dell server.
  3. Third-Party DAC Cables: Many third-party vendors (e.g., FS.com, Cisco, Finisar) offer DAC cables that are compatible with both Dell and Brocade devices. Ensure the cables are explicitly listed as compatible with both brands.
3. Where to Purchase in India
  1. Dell Authorized Resellers: Contact Dell’s authorized resellers or distributors in India. They can provide Dell-certified DAC cables and ensure compatibility with your PowerEdge R7625 server.
  2. Brocade/Extreme Networks Resellers: Since Brocade is now part of Extreme Networks, reach out to Extreme Networks resellers in India for Brocade-compatible DAC cables.
  3. Online Retailers
  4. Third-Party Vendors
4. Key Specifications to Confirm
  1. Cable Length: DAC cables are typically available in lengths ranging from 0.5m to 7m. Choose a length that suits your setup.
  2. Speed: Ensure the cable supports the required speed (e.g., 10Gbps for SFP+ or 40Gbps for QSFP+).
  3. Compatibility: Verify that the cable is compatible with both Dell and Brocade devices. Look for cables labeled as "multi-vendor compatible" if using third-party options.
5. Contacting Support
  1. Dell Support India: Reach out to Dell’s support team in India for assistance in sourcing compatible DAC cables. They can guide you to authorized resellers or provide part numbers for the cables.
  2. Extreme Networks Support: Contact Extreme Networks (Brocade) support for guidance on compatible cables for the BR-VDX6740-24-F switch.
6. Part Numbers to Look For
  1. Dell DAC cables typically have part numbers like 470-ABND (for SFP+ 10Gbps) or 470-ABND(for QSFP+ 40Gbps).
  2. Brocade DAC cables may have part numbers like 40G-QSFP-C-0101 (for QSFP+ 40Gbps).
If you provide more details about the port type and speed requirements, I can help narrow down the exact part numbers or vendors.
Hope This Helps!!!
AshSe
Forum Tips:
  1. Insert photos/images inline - don't attach.
  2. Always mark helpful and correct answers, it helps others find what they need.
  3. For a prompt reply, kindly tag @name. An email will be automatically sent to the member.
