07-12-2015 05:07 AM - edited 03-01-2019 07:57 AM
Hi friends,
Recently we have received two UCS, and trust me ia m very new hence don't know how to configure.
Pls. help me to deploy.
below is shw version & Inventry.
yourname#sh ver
Cisco IOS Software, C3900 Software (C3900-UNIVERSALK9-M), Version 15.3(3)M4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2014 by Cisco Systems, Inc.
Compiled Wed 24-Sep-14 08:26 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
yourname uptime is 11 minutes
System returned to ROM by reload at 11:36:18 UTC Sun Jul 12 2015
System image file is "flash0:c3900-universalk9-mz.SPA.153-3.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO3945-CHASSIS (revision 1.0) with C3900-SPE150/K9 with 1835264K/261888K bytes of memory.
Processor board ID FTX1905AHHK
7 Gigabit Ethernet interfaces
8 Serial(sync/async) interfaces
3 terminal lines
2 Channelized (E1 or T1)/PRI ports
1 Virtual Private Network (VPN) Module
2 cisco UCSE Module(s)
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
2005920K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 C3900-SPE150/K9 FOC19036QH5
Technology Package License Information for Module:'c3900'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security securityk9 Permanent securityk9
uc uck9 Permanent uck9
data datak9 Permanent datak9
NtwkEss None None None
CollabPro None None None
yourname#sh inventory
NAME: "CISCO3945-CHASSIS", DESCR: "CISCO3945-CHASSIS"
PID: CISCO3945-CHASSIS , VID: V02, SN: FTX1905AHHK
NAME: "Cisco Services Performance Engine 150 for Cisco 3900 ISR on Slot 0", DESCR: "Cisco Services Performance Engine 150 for Cisco 3900 ISR"
PID: C3900-SPE150/K9 , VID: V06 , SN: FOC19036QH5
NAME: "WAN Interface Card - HWIC Serial 2T on Slot 0 SubSlot 0", DESCR: "WAN Interface Card - HWIC Serial 2T"
PID: HWIC-2T , VID: V05 , SN: FOC18507HHW
NAME: "WAN Interface Card - HWIC Serial 2T on Slot 0 SubSlot 1", DESCR: "WAN Interface Card - HWIC Serial 2T"
PID: HWIC-2T , VID: V05 , SN: FOC18525FTS
NAME: "WAN Interface Card - HWIC Serial 2T on Slot 0 SubSlot 2", DESCR: "WAN Interface Card - HWIC Serial 2T"
PID: HWIC-2T , VID: V05 , SN: FOC18525GPV
NAME: "WAN Interface Card - HWIC Serial 2T on Slot 0 SubSlot 3", DESCR: "WAN Interface Card - HWIC Serial 2T"
PID: HWIC-2T , VID: V05 , SN: FOC18525GSC
NAME: "PVDM3 DSP DIMM with 128 Channels on Slot 0 SubSlot 4", DESCR: "PVDM3 DSP DIMM with 128 Channels"
PID: PVDM3-128 , VID: V01 , SN: FOC18527D3Z
NAME: "PVDM3 DSP DIMM with 128 Channels on Slot 0 SubSlot 5", DESCR: "PVDM3 DSP DIMM with 128 Channels"
PID: PVDM3-128 , VID: V01 , SN: FOC18527D3U
NAME: "Network Module Adapter for SM Slot on Slot 1", DESCR: "Network Module Adapter for SM Slot"
PID: SM-NM-ADPTR , VID: V01, SN: FOC18423VQL
NAME: "High Density Voice2 Network module with on board two port interface on Slot 1", DESCR: "High Density Voice2 Network module with on board two port interface "
PID: NM-HDV2-2T1/E1 , VID: V05 , SN: FOC18236M99
NAME: "UCSE Server Module on Slot 2", DESCR: "UCSE Server Module"
PID: UCS-E140S-M1/K9 , VID: V01 , SN: FOC183954B8
NAME: "UCSE Server Module on Slot 4", DESCR: "UCSE Server Module"
PID: UCS-E160D-M1/K9 , VID: V02 , SN: FOC18346RG2
NAME: "C3900 AC Power Supply 1", DESCR: "C3900 AC Power Supply 1"
PID: PWR-3900-AC , VID: V04 , SN: QCS19021DYB
yourname#
Sanjeev
07-21-2015 04:33 AM
Hi All,
Still waiting for an expert comments and support.
Reg
Sanjeev
