06-07-2015 04:21 AM - edited 03-01-2019 07:55 AM
Does the L2 Mac table , ARP communicate between different VDC.
ex:- Vlan 10 created in VDC1 and VDC2
does the L2 communication happen , mac/ARP etc.
how the spanning tree works for vlan10 on VDC1 and VDC2
how the fabric path works for vlan10 on VDC1 and VDC2
06-07-2015 09:26 PM
Creating Vlan 10 on VDC1 and VDC2 means that there is no communication between them untill you allow them to do.,
(Think like this that you have now created Vlan 10 on two different switches. (VDC1 is one switch and VDC2 is another switch).
MAC/ARP/STP/Fabric path are works independent to this now.,
Inayath
06-07-2015 09:29 PM
Each VDC is its own switch. They have their own processes, VLANs, routing protocols, spanning-tree, management plane, and configuration. It's really a completely separate switch. Interfaces are assigned to the VDC to provide external connectivity. Inter-VDC communication is only via external interfaces, there is no internal switch like in VMware.
So if you are planning to have inter communication between the three VDCs, then you need to add a link between the different VDC's.
Are you planning to have 1G interfaces of a LC to be a part of different VDCs & these 1G interfaces would be used for inter VDC communication, whereas the external facing interfaces on all these VDCs would be of 10 G capacity.
regards
Inayath
