Distribute list in Nexus 7K to allow only default route
smondal10765614
Level 5
Level 5
Hi All,
We are about to migrate our core routers into two Nexus 7Ks with four VDCs each.
I was planning to permit only the default route (0.0.0.0) into the building aggregation switch (Cisco 6509). I planned to use distribute-list as I have done it in IOS and I could allow it through any specific interface I want.
Well, how do I do that in Nexus 7K? I don't see any distrubute list option. I can use prefix list, but then how do I specify the particular interface?
Many thanks in advance.
Mondal
CCIE #29034
smondal10765614
Level 5
Level 5
Well, I found my own answer!
Here is the command that goes on the Interface. I kept typing IP eigrp and hence did not get any option! Thanks for looking. You do offset-list the same way.
ip distribute-list eigrp Test1 route-map EigrpTest in
