Error Java when installing DCNM 6.3
mhuaynate
Hi my friend:
Some have this problem when installing DCNM 6.3 on windows 2012 R2 standard java 8.0
Thank for all
Marco.
Eric Scott
Hi Marco,
When you get the fatal application error, can you click on details to see the full exception?  Most commonly, you will see "Flexeraaxx$aaa: Windows DLL failed to load".  If that is the case, then try running the DCNM installer in compatibility mode.
Right-click on the dcnm-installer-x65.exe file and select "Troubleshoot compatibility".  Then, select "Troubleshoot program" -> Select "The program worked in earlier version of Windows but won't install or run now" -> Select Windows 7 or WIndows 8 -> Start the Program.
-Eric
Eric Scott
Hi Marco,
-Eric
