Failed to deploy HX Edge using Intersight SaaS
SIMMN
Like the title said but I do not know why OR I do not understand the error message...
This is the step during deployment:
Then here is the error came up:Capture1.PNG
Is it the login to HX node CIMC? If so, where do I go to enter the credential...
I can launch IMC from within Intersight for my HX Edge without issue.
Please help!
SIMMN
Replying myself here...
The issue has nothing to do with CIMC even the error message says so...misleading to say at least...
The issue was the default ESXi password in case you wonder.
SIMMN
