Finding out RCA for the Network Fluctuations at Server level connected to N5K's
abhi.sharma2015
Hi All
I'm having trouble finding RCA for around 100 plus server blades (7 IBM Enclosures) got network fluctuation causing some application stop on these servers.
Topology:
Server-1 blades(14 no.'s)-->IBM Switch embedded (L2)-->Port X/Y of N5K(each port X/Y is a member of Port-channel XX)
Server-2 blades(14 no.'s)--> same as above-->Port X2/Y2 of same N5K
-----list goes on to Server 7 Connecting to same N5K (2 no. in Redundant fashion)
Suspecting issue:
 At same time, a team member was doing troubleshooting on a Port-channel which is not related to these enclosures Port-channels but on the common switch A. All enclosures Port-channels and troubleshooted Port-channels have same Vlan running in deep down to Servers.
Now my question is
1. if some-one doing shut, no shut of port-channel, deleting and then reapplying VPC for that PO, Creating new PO and VPC will effect another PO's and VPC's in such extent that around 7 PO's in that switch goes down and become member less of their respective ports.
2. How likely it is if some config changes in a neighboring VPC,PO's can cause malfunctioning of other PO's running in same switch.
PFA the toptology.
0 Replies 0
