Got 'return code 0x404F0003' while running 'install all' under a Nexus 5020 switch
johchen
Hi  Lucien,
While I was trying to upgrade the NX-OS of a Nexus 5020 switch from  4.1(3)N1(1) to 5.2(1)N1(3), I encoutered the following error.
Would you please show me a way out?
fcoesw(config)# install all kickstart bootflash:n5000-uk9-kickstart.5.2.1.N1.3.bin system bootflash:n5000-uk9.5.2.1.N1.3.bin
Verifying image bootflash:/n5000-uk9-kickstart.5.2.1.N1.3.bin for boot variable "kickstart".
[####################] 100% -- SUCCESS
Verifying image bootflash:/n5000-uk9.5.2.1.N1.3.bin for boot variable "system".
Verifying image type.
Extracting "system" version from image bootflash:/n5000-uk9.5.2.1.N1.3.bin.
[#                   ]   0% -- FAIL. Return code 0x404F0003 (SRG file not present/cannot be opened).
Version Compatibility check failed. Return code 0x40930012 (SRG extraction failed).
Unable to send exit to installer. Return code -1
current version information:
fcoesw(config)# show version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2009, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 1.2.0
  loader:    version N/A
  kickstart: version 4.1(3)N1(1)
  system:    version 4.1(3)N1(1)
  BIOS compile time:       06/19/08
  kickstart image file is: bootflash:/n5000-uk9-kickstart.4.1.3.N1.1.bin
  kickstart compile time:  7/23/2009 17:00:00 [07/24/2009 00:53:59]
  system image file is:    bootflash:/n5000-uk9.4.1.3.N1.1.bin
  system compile time:     7/23/2009 17:00:00 [07/24/2009 01:42:52]
Hardware
  cisco Nexus5020 Chassis ("40x10GE/Supervisor")
  Intel(R) Celeron(R) M CPU    with 2074284 kB of memory.
  Processor Board ID JAB12330051
  Device name: fcoesw
  bootflash:    1003520 kB
Kernel uptime is 0 day(s), 1 hour(s), 45 minute(s), 0 second(s)
Last reset at 184469 usecs after  Sun Feb 17 01:06:15 2013
  Reason: Reset Requested by CLI command reload
  System version: 4.1(3)N1(1)
  Service:
plugin
  Core Plugin, Ethernet Plugin
Output of 'show system internal flash':
fcoesw(config)# show system internal flash
Mount-on                  1K-blocks      Used   Available   Use%  Filesystem
/                            204800     89544      115256     44   /dev/root
/proc                             0         0           0      0   proc
/post                          2048         4        2044      1   none
/sys                              0         0           0      0   none
/isan                        512000    337768      174232     66   none
/var/tmp                     102400       100      102300      1   none
/var/sysmgr                  512000         4      511996      1   none
/var/sysmgr/ftp              204800     17736      187064      9   none
/var/sysmgr/ftp/cores         20480         0       20480      0   none
/callhome                     32768         0       32768      0   none
/dev/shm                     262144     95984      166160     37   none
/volatile                     61440         0       61440      0   none
/debug                         2048         4        2044      1   none
/dev/mqueue                       0         0           0      0   none
/mnt/cfg/0                    39257      4347       32883     12   /dev/sda5
/mnt/cfg/1                    37242      4347       30972     13   /dev/sda6
/var/sysmgr/startup-cfg      102400      4036       98364      4   none
/dev/pts                          0         0           0      0   devpts
/mnt/plog                     56192      4928       51264      9   /dev/mtdblock2
/mnt/pss                      39273      5106       32139     14   /dev/sda4
/bootflash                   859848    626036      190132     77   /dev/sda3
I am looking forward to your reply, thank you so much in advance.
Jevon
fb_webuser
Level 6
Level 6
I havent looked into your error codes too deeply, but I think it might be a version issue. You might need to upgrade to a later version 4 code, before attempting to upgrade to 5.2. Please check your release notes and upgrade specs.
Posted by WebUser Adriaan Steyn from Cisco Support Community App
alain.alonso
reload the system to clear the temp
happiness!!!! :-)
........# show install all impact kickstart bootflash:n6000-uk9-kickstart.6.0.2.N2.4.bin system bootflash:n6000-uk9.6.0.2.N2.4.bin
Verifying image bootflash:/n6000-uk9-kickstart.6.0.2.N2.4.bin for boot variable "kickstart".
Verifying image bootflash:/n6000-uk9.6.0.2.N2.4.bin for boot variable "system".
Extracting "system" version from image bootflash:/n6000-uk9.6.0.2.N2.4.bin.
Extracting "kickstart" version from image bootflash:/n6000-uk9-kickstart.6.0.2.N2.4.bin.
Extracting "bios" version from image bootflash:/n6000-uk9.6.0.2.N2.4.bin.
Extracting "fexth" version from image bootflash:/n6000-uk9.6.0.2.N2.4.bin.
Performing module support checks.
Notifying services about system upgrade.
