HX Installer Deploy Failed
Networker_eg
As I was trying to rebuild a cluster one of the nodes failed deployment as per attached
Have anyone seen this before ?
Do you know a work around ?
Amr
f.henco
Try to untick the box 'remove disk partitions' in config JSON file
https://www.cisco.com/c/en/us/td/docs/hyperconverged_systems/HyperFlex_HX_DataPlatformSoftware/Installation_VMWare_ESXi/3_5/b_HyperFlexSystems_Installation_Guide_for_VMware_ESXi_3_5/b_HyperFlex_Systems_GettingStartedGuide_3_0_chapter_01.html#id_13130
New factory servers are shipped with appropriate disk partition settings. Do not remove disk partitions from new factory servers.
