Hyperflex node expansion for a Cluster using API
ShishirDash5204
Level 2
Level 2
Hello ,
Looking at the Hyperflex API documentation I got to know we can expand nodes for a Cluster . Just need to understand the payload
"hosts": [
"uuid": "string",
"role": "UNKNOWN",
"serialnumber": "string",
"model": "string",
"fqdn": "string",
"managementip": "string",
"dataip": "string",
"livemigrationip": "string"
"hxvms": [
"uuid": "string",
"vmid": "string",
"hostuuid": "string",
"fqdn": "string",
"dataip": "string"
I got to know the Host details.
What does HXVms section refers to ? Is it refering to controller vm? I'll appreciate your help for explaining the details under hxvms list for the payload.
KyoCode
Level 2
Level 2
Hi !
HXVMs section corresponds to SCVM controller on top of Converged node, yes, unless you're not using EAM nor Converged nodes, hence Compute-only nodes won't require that information for an expansion,
what's the concern in that regard? if previous detail satisfied your concern,
AIV
