Heads Up :
The post you are writing will appear in a public forum. Please ensure all content is appropriate for public consumption. Review the employee guidelines for the community here.
Hi guys,
since a few days i have the issue that my terraform apply don't work anymore. A few weeks ago it worked fine and i don't changed any versions.
Anytime when i try to deploy Access Policies is see the following change:
# module.aci.module....
I have a Prod network with the following Switches as Core: Cisco9336C-FX2 36Port 40/100G port density.Our Link is only 100Mbps and can go up to 1G and we intend to install a Similar Model Switch at DR for Active/Active Replication.We intend to achiev...
I want to start using API to automate what Cisco connect dots (Connect Dots (cisco.com)) and cisco coverage checker (Device Coverage Checker (cisco.com)) sites are providing.
Any recommendations and API documentation on how to receive information if ...
Hi all,Not too sure if I am in the right area; but got an issue of trying to work out what TimeZone the date & time supplied back via the REST API is. Below is an example output, I am trying to work on. I can solve what ACST is (as it is unique and t...
Hello ,Looking at the Hyperflex API documentation I got to know we can expand nodes for a Cluster . Just need to understand the payload {"hosts": [{"uuid": "string","role": "UNKNOWN","serialnumber": "string","model": "string","fqdn": "string","manage...
I was wondering what would be the preferred way of getting a list of all clients (lan and wifi) for a site using the intent API.
I can see the API call https://developer.cisco.com/docs/dna-center/#!get-client-detail that will provide details fo...
Hi all, I am working on a project and I need some information that datasheets don't give. In need de Mean Time Between Failure (MTBF) of FPR1010-NGFW-K9. The problema is that the datasheet don't give this information and the values for calculating it...
Hello! I booked ACI HW lab to practice with real HW not only with APIC, but there wasn't any HW equipment. I'm really disappointed Maybe I did something wrong? Or is there a temporary issue with HW and it will appear soon?
