08-29-2016 03:20 PM - edited 03-01-2019 08:21 AM
In my Job have a Nexus 7000 and i can't use Ethanalyzer ¿Anybody could help me?
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2014, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under
license. Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or the GNU
Lesser General Public License (LGPL) Version 2.1. A copy of each
such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://www.opensource.org/licenses/lgpl-2.1.php
NX7706-1# sh ver
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_
series_home.html
Software
BIOS: version 3.1.0
kickstart: version 6.2(10)
system: version 6.2(10)
BIOS compile time: 02/27/2013
kickstart image file is: bootflash:///n7700-s2-kickstart.6.2.10.bin
kickstart compile time: 10/9/2014 12:00:00 [10/17/2014 05:45:04]
system image file is: bootflash:///n7700-s2-dk9.6.2.10.bin
system compile time: 10/9/2014 12:00:00 [10/17/2014 07:39:17]
Hardware
cisco Nexus7700 C7706 (6 Slot) Chassis ("Supervisor Module-2")
Intel(R) Xeon(R) CPU with 32745060 kB of memory.
08-29-2016 08:03 PM
Hi ,
Ethanalyzer should work on it. Are you seeing any error ?
http://www.cisco.com/c/en/us/support/docs/switches/nexus-7000-series-switches/116136-trouble-ethanalyzer-nexus7000-00.html#anc10
Thanks-
Afroz
***Ratings Encourages Contributors ***
08-30-2016 08:12 AM
This is the error.
NX7706-1# ethanalyzer
% Invalid command at '^' marker.
08-30-2016 06:27 PM
share the show version of the device
Thanks-
09-02-2016 12:19 PM
This is my show version
NX7706-1# sh ver
series_home.html
Software
BIOS: version 3.1.0
Hardware
09-02-2016 04:40 PM
Hi ,
you need to run the Ethanalyzer from ADMIN VDC. you will not be able to run from non-admin VDC.
use ADMIN -VDC , it should work :)
Thanks-
Afroz
09-03-2016 02:14 PM
But it is in a Admin-vdc, i don't have activate this vdc.
And if i want activate it will be a cut in the traffic in my switch.
I only need ethanalyzer, but i can't active this vdc in my company switch.
I need other solution.
09-03-2016 07:03 PM
as far as i know , ethanalyzer can only be ran from admin VDC :(
