If a site has two WaaS appliances
bbalsley
If a site has two WaaS appliances, can one work at peak performance while the secondary takes over when needed  (e.g. if the primary reaches its connection limit) or should the connections be equal between the two appliances?
Hi ,
 How WAE devices is operated in your network inline method or Transparent method (WCCP or PBR) .
Sandy
