Interface breakout module
-Ypsilon-
Could someone comment on any caveats when adding second breakout cable with the command interface breakout module 1 port X map 10g-4x switch on a 9332pq?
I have currently a breakout and a config looking like this: interface breakout module 1 port 18 map 10g-4x
If I want to add a breakout on 17 should I just go with:
interface breakout module 1 port 17 map 10g-4x  (will it merge into 17-18 or delete 18?)
  or   interface breakout module 1 port 17,18 map 10g-4x.
I am trying to avoid a scenario (if any) of accidentally deleting the configs of ports 1/18/x.
Thanks!
driss JABBAR
Hello -Ypsilon
The  interface breakout module 1 port 17,18 map 10g-4x will create  subinterfaces under parent Ethernet interfaces 17 and 18 and will not delete any  previous configs
when you enter "show interface status you will get something like this:
Eth 1/17/1
Eth 1/17/2
Eth 1/17/3
Eth 1/17/4
Eth 1/18/1
Eth 1/18/2
Eth 1/18/3
Eth 1/18/4
Hope this helps !!!
Thanks for the response!
So
- if I "port 17,18 map" it will break 17 and will keep my running conf on the already broken 18 intact as you say.
- What if I "port 17 map"? Will it just add 17 and keep 18 intact?
Yes you can go and configure only the eth port 17 without touching the port 18
Thanks Driss I will try that.
