Hi Experts,
I am trying to use ITD to load balance between multiple servers in my data center, the expected throughput is between 60 - 120 Gbps with multiple 10 Gbps links, I could use either the N9K (N9K-93108TC-EX , IOS-XE: 7.0(3)) ToR switch or the N7K (N7K-C7009 , IOS-XE: 6.2 (16)), I know that ITD is ASIC based, so ther should be almost no impact on the CPU or memory utilization of the switch, however, I could not find any document on this, I found an old discussion on ITD for firewalls clustering, but most of the links there do not work
https://community.cisco.com/t5/firewalls/scaling-the-firewall-performance-while-providing-higher/td-p/2602007
Wise
