Loadbalancing 2 and routing 1 server
steve switzer
Hi      All
Thanks to some help from marcel I have managed to set up a test loadbalancing environment.
However my plan was to have 2 servers loadbalanced and one just straight routed.
This doesnt work with my current setup - which is as follows -
admin context -
boot system image:c4710ace-mz.A4_2_0.bin
interface gigabitEthernet 1/1
  switchport trunk allowed vlan 121
  no shutdown
interface gigabitEthernet 1/2
  switchport access vlan 1000
  no shutdown
interface gigabitEthernet 1/3
  switchport trunk allowed vlan 122
  no shutdown
interface gigabitEthernet 1/4
  shutdown
access-list ALL line 8 extended permit ip any any
class-map type management match-any remote_access
  2 match protocol xml-https any
  3 match protocol icmp any
  4 match protocol telnet any
  5 match protocol ssh any
  6 match protocol http any
  7 match protocol https any
  8 match protocol snmp any
policy-map type management first-match remote_mgmt_allow_policy
  class remote_access
    permit
interface vlan 1000
  ip address xx.xx.253.20 255.255.255.0
  access-group input ALL
  service-policy input remote_mgmt_allow_policy
  no shutdown
context Testing-11
  description Testing Context
  allocate-interface vlan 121-122
  allocate-interface vlan 199-342
  allocate-interface vlan 1000
Testing context -
access-list EVERYONE line 8 extended permit tcp any any
access-list INBOUND line 1 extended permit tcp host  xx.xx.253.4 any
rserver host TEST-1
  ip address xx.xx.122.200
  inservice
rserver host TEST-2
  ip address xx.xx.122.201
  inservice
rserver host TEST-3
  ip address xx.xx.122.3
  inservice
serverfarm host TESTFARM
  rserver TEST-1
    inservice
  rserver TEST-2
    inservice
class-map type management match-any REMOTE-ACCESS
  2 match protocol icmp any
  3 match protocol telnet any
  4 match protocol ssh any
  5 match protocol https any
  7 match protocol xml-https any
class-map match-all VIP-150
  2 match virtual-address xx.xx.121.150 any
class-map match-all slb-vip
policy-map type management first-match MGMT_TEST
  class REMOTE-ACCESS
    permit
policy-map type loadbalance first-match lb-logic
  class class-default
    serverfarm TESTFARM
policy-map multi-match CLIENT-VIPS
  class VIP-150
    loadbalance vip inservice
    loadbalance policy lb-logic
interface vlan 121
  description Clients
  ip address xx.xx.121.10 255.255.255.0
  access-group input EVERYONE
  service-policy input CLIENT-VIPS
  service-policy input MGMT_TEST
  no shutdown
interface vlan 122
  description Servers Vlan
  ip address xx.xx.122.10 255.255.255.0
  no shutdown
interface vlan 1000
  ip address 10.14.253.21 255.255.255.0
  no shutdown
ip route 0.0.0.0 0.0.0.0 xx.xx.121.1
Like i said TEST-1 and TEST-2 are loadbalancing ok
but i cannot get to the webserver TEST-3 ehich is not
supposed to be loadbalanced.
Thanks in advance
Steve
Marcel Zehnder
Hi Steve
Theres no need to configure the third server on the ACE if you just want to route traffic to it:
no rserver host TEST-3
You may also change your ACL:
no access-list EVERYONE line 8 extended permit tcp any any
access-list EVERYONE extended permit ip any any
-Check the configuration of your Server TEST-3. Is xx.xx.122.10 configured as the default-gateway on your server?
-On your device with the IP xx.xx.121.1 (it's a router/layer 3 switch or a firewall, I think) do you have a route for your server subnet pointing to the ACE (ie ip route xx.xx.122.0 255.255.255.0 xx.xx.121.10)?
Maybe there is a layer 2 issue - your server TEST-3 is configured in vlan122, right? Could you please post the following outputs from your ACE:
show arp
show ip route
Marcel
Marcel Zehnder
Hi Steve
show arp
show ip route
Marcel
hi maur.........marcel ;-)
Thanks again - i now have 3 web servers set up -
can talk to one via routing and the other 2 are supposed
to be loadbalancing.
When i do the command - sh service-policy CLIENT-VIPS detail
i can see the -
curr conns       : 1         , hit count        : 45
incrementing - but when i look at the servers only one is incrementing
i can ping both from the ACE 4710.
Still we are getting somewhere.
Steve
Problem solved thanks marcel have a very nice day !!!!
