logging source-interface command on Nexus
bilalhussain
Hi - I am trying to configure logging on Nexus and want to use source interface as mgmt0.
But when I type the command
Nexus# logging source-interface ?
I only see Loopback interface as option. I do not see any other interfaces as an options.
I don't know what is the issue.
Can you please advise
NEXUS# sh ver
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Documents: http://www.cisco.com/en/US/products/ps9372/tsd_products_support_serie
s_home.html
Copyright (c) 2002-2016, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Software
  BIOS:      version 2.1.7
  Power Sequencer Firmware:
             Module 1: v4.0
             Module 1: v4.0
  Fabric Power Sequencer Firmware: Module 1: version v4.0
  Microcontroller Firmware:        version v0.0.0.15
  QSFP Microcontroller Firmware:
             Module 1: v2.0.0.0
             Module 1: v1.3.0.0
  CXP Microcontroller Firmware:
             Module not detected
  kickstart: version 7.1(4)N1(1)
  system:    version 7.1(4)N1(1)
  BIOS compile time:       06/16/2016
  kickstart image file is: bootflash:///n6000-uk9-kickstart.7.1.4.N1.1.bin
  kickstart compile time:  9/2/2016 10:00:00 [09/02/2016 20:17:17]
  system image file is:    bootflash:///n6000-uk9.7.1.4.N1.1.bin
  system compile time:     9/2/2016 10:00:00 [09/02/2016 20:18:08]
Hardware
  cisco Nexus 5672UP Chassis ("Nexus 5672UP Supervisor")
  Intel(R) Xeon(R) CPU  @ 1.80 with 8243332 kB of memory.
  Processor Board ID FOC21052NZ4
  Device name: GBSYGDCARZ900
  bootflash:    7692288 kB
Kernel uptime is 568 day(s), 0 hour(s), 25 minute(s), 18 second(s)
Last reset
  Reason: Unknown
  System version: 7.1(4)N1(1)
  Service:
plugin
  Core Plugin, Ethernet Plugin
0 Replies 0
