11-08-2017 08:51 AM - edited 03-01-2019 08:39 AM
I have issue with N2K-C2348UPQ4F,
First time we connected to N7K with 7.3.(2)D1(1) for 2 weeks,
after that we disconnect from N7K and connect to N5K-C5648Q with 7.1(4)N1(1) but N2K does't came up ,
Can you advise what should we do ?
Below are step what we face:
once we connect N2K to N5K it's image download
N5K_01# sh fex
FEX FEX FEX FEX Fex
Number Description State Model Serial
100 FEX0100 Image Download N2K-C2348UPQ-10GE FOCX1X2R1XX
after reboot N2K it became offline
N5K_01# sh fex
FEX FEX FEX FEX Fex
100 FEX0100 Offline N2K-C2348UPQ-10GE FOCX1X2R1XX
11-08-2017 09:17 AM - edited 11-08-2017 09:17 AM
It's because each Parent switch has it's own kickstart and system images for the FEX, when you moved that from the N7K to the N5K it won't work
You'll have to upgrade the FEX's kickstart and system images
See this link for instructions.
https://www.cisco.com/c/en/us/td/docs/switches/datacenter/nexus2000/sw/configuration/guide/rel_4_0_1a/NX2000CLIConfig/FEX-Config.html#75788
11-08-2017 11:14 PM
Hi RIck,
is it possible to downgrade N7K to 7.1(4)N1 ? , so it will same as N5K ,
11-10-2017 07:53 AM
Good question, I don’t believe so as there completly different OS’s for each system. You can however reload the fex on the N5K which shouldn’t give you an issue.
11-28-2017 06:03 AM
Hi Rick,
i have some difficult with N5K due to it's in production and can't able to reload and tested with N5K,
is that possible downgrade with N9K instead of N5K ? after downgrade with N9K , i will connect to N5K, is that possible ? , thanks.
11-28-2017 08:03 AM
11-28-2017 08:40 AM
Hi Rick,
sorry about my understanding, download the image meaning that I need to download the 7.3.(2)D1(1) and upgrade N5K ?
11-29-2017 08:39 AM
11-29-2017 07:03 PM
Hi Rack,
after I connected, N2K is offline, is that possible install image with offline ? ,
the main problem is N2K doesn't online ,
thanks.
11-29-2017 07:36 PM
Yes you should be able.
05-24-2018 06:25 PM
1. Remove the NIF/HIF (ports connecting FEX and N5K) connections of 2348UPQ from 5624Q Parent switch.
2. Connect the FEX back again to N7k and make it online.
3. Load the dplug image matching the N7k image (load bootflash:<dplug filename>)
4. Now rlogin to the FEX as root. (rlogin -l root 127.1.1.<fexid>)
5. Do rm -rf /mnt/sysimage/*
6. Remove Physical NIF connections and HIF port connections if any (fex will shut off, thats fine)
7. Connect the FEX back up to the N5k/N6k. Now the FEX should come up
