04-19-2018 08:45 AM - edited 03-01-2019 08:46 AM
Hi. I'm new to nexus. I haven't being able to find what's wrong. I can't see any misconfig errors. But facing consistency check. Tried even write erase and start the environment all over again. But the Consistency check problems reappear. Pls help.
The topology is as follows:
n5548-1 --------------n5548-2
n2224tp n2224tp
See topology attached as well.
N5k nx-os 7.0.5
Follow config:
n5k-1
fex 101
pinning max-links 1
description "FEX0101"
fex 102
pinning max-links 1
description "FEX0102"
vpc domain 1
peer-keepalive destination 10.10.48.203
interface port-channel30
switchport mode trunk
spanning-tree port type network
speed 10000
vpc peer-link
interface port-channel101
switchport mode fex-fabric
fex associate 101
vpc 101
interface port-channel102
fex associate 102
vpc 102
interface Ethernet1/1
fex associate 101
channel-group 101
interface Ethernet1/2
fex associate 102
channel-group 102
interface Ethernet1/30
description Po30_BACK-TO-BACK-VLC-PEER-LINK_TO-->NEXUS-10.10.48.203
channel-group 30
interface Ethernet1/31
channel-group 30
interface Ethernet1/32
description TO-->CORE1
switchport trunk allowed vlan 64,2320
interface mgmt0
vrf member management
ip address 10.10.48.202/23
nexus-10.10.48.202# show vpc
Legend:
(*) - local vPC is down, forwarding via vPC peer-link
vPC domain id : 1
Peer status : peer adjacency formed ok
vPC keep-alive status : peer is alive
Configuration consistency status : success
Per-vlan consistency status : success
Type-2 consistency status : success
vPC role : primary
Number of vPCs configured : 50
Peer Gateway : Disabled
Dual-active excluded VLANs : -
Graceful Consistency Check : Enabled
Auto-recovery status : Enabled (timeout = 240 seconds)
vPC Peer-link status
id Port Status Active vlans
1 Po30 up 1,64,2320
vPC status
id Port Status Consistency Reason Active vlans
101 Po101 up success success -
102 Po102 up success success -
102400 Eth101/1/1 down* Not Consistency Check Not -
Applicable Performed
102401 Eth101/1/2 down* Not Consistency Check Not -
102402 Eth101/1/3 down* Not Consistency Check Not -
102403 Eth101/1/4 down* Not Consistency Check Not -
102404 Eth101/1/5 down* Not Consistency Check Not -
102405 Eth101/1/6 down* Not Consistency Check Not -
102406 Eth101/1/7 down* Not Consistency Check Not -
102407 Eth101/1/8 down* Not Consistency Check Not -
102408 Eth101/1/9 down* Not Consistency Check Not -
102409 Eth101/1/10 down* Not Consistency Check Not -
102410 Eth101/1/11 down* Not Consistency Check Not -
102411 Eth101/1/12 down* Not Consistency Check Not -
102412 Eth101/1/13 down* Not Consistency Check Not -
102413 Eth101/1/14 down* Not Consistency Check Not -
102414 Eth101/1/15 down* Not Consistency Check Not -
102415 Eth101/1/16 down* Not Consistency Check Not -
102416 Eth101/1/17 down* Not Consistency Check Not -
102417 Eth101/1/18 down* Not Consistency Check Not -
102418 Eth101/1/19 down* Not Consistency Check Not -
102419 Eth101/1/20 down* Not Consistency Check Not -
102420 Eth101/1/21 down* Not Consistency Check Not -
102421 Eth101/1/22 down* Not Consistency Check Not -
102422 Eth101/1/23 down* Not Consistency Check Not -
102423 Eth101/1/24 down* Not Consistency Check Not -
103424 Eth102/1/1 down* Not Consistency Check Not -
103425 Eth102/1/2 down* Not Consistency Check Not -
103426 Eth102/1/3 down* Not Consistency Check Not -
103427 Eth102/1/4 down* Not Consistency Check Not -
103428 Eth102/1/5 down* Not Consistency Check Not -
103429 Eth102/1/6 down* Not Consistency Check Not -
103430 Eth102/1/7 down* Not Consistency Check Not -
103431 Eth102/1/8 down* Not Consistency Check Not -
103432 Eth102/1/9 down* Not Consistency Check Not -
103433 Eth102/1/10 down* Not Consistency Check Not -
103434 Eth102/1/11 down* Not Consistency Check Not -
103435 Eth102/1/12 down* Not Consistency Check Not -
103436 Eth102/1/13 down* Not Consistency Check Not -
103437 Eth102/1/14 down* Not Consistency Check Not -
103438 Eth102/1/15 down* Not Consistency Check Not -
103439 Eth102/1/16 down* Not Consistency Check Not -
103440 Eth102/1/17 down* Not Consistency Check Not -
103441 Eth102/1/18 down* Not Consistency Check Not -
103442 Eth102/1/19 down* Not Consistency Check Not -
103443 Eth102/1/20 down* Not Consistency Check Not -
103444 Eth102/1/21 down* Not Consistency Check Not -
103445 Eth102/1/22 down* Not Consistency Check Not -
103446 Eth102/1/23 down* Not Consistency Check Not -
103447 Eth102/1/24 down* Not Consistency Check Not -
nexus-10.10.48.202#
nexus-10.10.48.202# show int status
Port Name Status Vlan Duplex Speed Type
Eth1/1 -- connected 1 full 10G 10Gbase-SR
Eth1/2 -- connected 1 full 10G 10Gbase-SR
Eth1/3 -- notconnec 1 full 10G 10Gbase-SR
Eth1/4 -- notconnec 1 full 10G 10Gbase-SR
Eth1/5 -- sfpAbsent 1 full 10G --
Eth1/6 -- sfpAbsent 1 full 10G --
Eth1/7 -- sfpAbsent 1 full 10G --
Eth1/8 -- sfpAbsent 1 full 10G --
Eth1/9 -- sfpAbsent 1 full 10G --
Eth1/10 -- sfpAbsent 1 full 10G --
Eth1/11 -- sfpAbsent 1 full 10G --
Eth1/12 -- sfpAbsent 1 full 10G --
Eth1/13 -- sfpAbsent 1 full 10G --
Eth1/14 -- sfpAbsent 1 full 10G --
Eth1/15 -- sfpAbsent 1 full 10G --
Eth1/16 -- sfpAbsent 1 full 10G --
Eth1/17 -- sfpAbsent 1 full 10G --
Eth1/18 -- sfpAbsent 1 full 10G --
Eth1/19 -- sfpAbsent 1 full 10G --
Eth1/20 -- sfpAbsent 1 full 10G --
Eth1/21 -- sfpAbsent 1 full 10G --
Eth1/22 -- sfpAbsent 1 full 10G --
Eth1/23 -- sfpAbsent 1 full 10G --
Eth1/24 -- sfpAbsent 1 full 10G --
Eth1/25 -- sfpAbsent 1 full 10G --
Eth1/26 -- sfpAbsent 1 full 10G --
Eth1/27 -- sfpAbsent 1 full 10G --
Eth1/28 -- sfpAbsent 1 full 10G --
Eth1/29 -- sfpAbsent 1 full 10G --
Eth1/30 Po30_BACK-TO-BACK- connected trunk full 10G 10Gbase-SR
Eth1/31 Po30_BACK-TO-BACK- connected trunk full 10G 10Gbase-SR
Eth1/32 TO-->CORE1 notconnec trunk full 10G 10Gbase-SR
Po30 -- connected trunk full 10G --
Po101 -- connected 1 full 10G --
Po102 -- connected 1 full 10G --
mgmt0 -- connected routed full a-1000 --
Eth101/1/1 -- notconnec 1 auto auto --
Eth101/1/2 -- notconnec 1 auto auto --
Eth101/1/3 -- notconnec 1 auto auto --
Eth101/1/4 -- notconnec 1 auto auto --
Eth101/1/5 -- notconnec 1 auto auto --
Eth101/1/6 -- notconnec 1 auto auto --
Eth101/1/7 -- notconnec 1 auto auto --
Eth101/1/8 -- notconnec 1 auto auto --
Eth101/1/9 -- notconnec 1 auto auto --
Eth101/1/10 -- notconnec 1 auto auto --
Eth101/1/11 -- notconnec 1 auto auto --
Eth101/1/12 -- notconnec 1 auto auto --
Eth101/1/13 -- notconnec 1 auto auto --
Eth101/1/14 -- notconnec 1 auto auto --
Eth101/1/15 -- notconnec 1 auto auto --
Eth101/1/16 -- notconnec 1 auto auto --
Eth101/1/17 -- notconnec 1 auto auto --
Eth101/1/18 -- notconnec 1 auto auto --
Eth101/1/19 -- notconnec 1 auto auto --
Eth101/1/20 -- notconnec 1 auto auto --
Eth101/1/21 -- notconnec 1 auto auto --
Eth101/1/22 -- notconnec 1 auto auto --
Eth101/1/23 -- notconnec 1 auto auto --
Eth101/1/24 -- notconnec 1 auto auto --
Eth102/1/1 -- notconnec 1 auto auto --
Eth102/1/2 -- notconnec 1 auto auto --
Eth102/1/3 -- notconnec 1 auto auto --
Eth102/1/4 -- notconnec 1 auto auto --
Eth102/1/5 -- notconnec 1 auto auto --
Eth102/1/6 -- notconnec 1 auto auto --
Eth102/1/7 -- notconnec 1 auto auto --
Eth102/1/8 -- notconnec 1 auto auto --
Eth102/1/9 -- notconnec 1 auto auto --
Eth102/1/10 -- notconnec 1 auto auto --
Eth102/1/11 -- notconnec 1 auto auto --
Eth102/1/12 -- notconnec 1 auto auto --
Eth102/1/13 -- notconnec 1 auto auto --
Eth102/1/14 -- notconnec 1 auto auto --
Eth102/1/15 -- notconnec 1 auto auto --
Eth102/1/16 -- notconnec 1 auto auto --
Eth102/1/17 -- notconnec 1 auto auto --
Eth102/1/18 -- notconnec 1 auto auto --
Eth102/1/19 -- notconnec 1 auto auto --
Eth102/1/20 -- notconnec 1 auto auto --
Eth102/1/21 -- notconnec 1 auto auto --
Eth102/1/22 -- notconnec 1 auto auto --
Eth102/1/23 -- notconnec 1 auto auto --
Eth102/1/24 -- notconnec 1 auto auto --
nexus-10.10.48.202# show fex
FEX FEX FEX FEX Fex
Number Description State Model Serial
101 FEX0101 Online N2K-C2224TP-1GE SSI184700WQ
102 FEX0102 Online N2K-C2224TP-1GE SSI184700WY
nexus-10.10.48.202# show vpc consistency-parameters interface po 101
Legend:
Type 1 : vPC will be suspended in case of mismatch
Name Type Local Value Peer Value
Fex id 1 101 101
Shut Lan 1 No No
STP Port Type 1 Default Default
STP Port Guard 1 None None
STP MST Simulate PVST 1 Default Default
mode 1 on on
Speed 1 10 Gb/s 10 Gb/s
Duplex 1 full full
Port Mode 1 fex-fabric fex-fabric
MTU 1 1500 1500
Admin port mode 1 unknown unknown
vPC card type 1 Empty Empty
Allowed VLANs -
Local suspended VLANs - - -
nexus-10.10.48.202# show vpc consistency-parameters interface po 102
Legend:
Fex id 1 102 102
Shut Lan 1 No No
mode 1 on on
Duplex 1 full full
MTU 1 1500 1500
Allowed VLANs -
nexus-10.10.48.202#
n5k-2
fex 101
pinning max-links 1
fex 102
pinning max-links 1
vpc domain 1
peer-keepalive destination 10.10.48.202
speed 10000
vpc peer-link
fex associate 101
vpc 101
fex associate 102
vpc 102
fex associate 101
channel-group 101
fex associate 102
channel-group 102
description Po30_BACK-TO-BACK-VLC-PEER-LINK_TO-->NEXUS-10.10.48.202
channel-group 30
channel-group 30
description TO-->CORE2
interface mgmt0
ip address 10.10.48.203/23
nexus-10.10.48.203# show vpc br
Legend:
vPC domain id : 1
vPC role : secondary
1 Po30 up 1,64,2320
vPC status
