Nexus 7K 802.1AE (MACsec)
If my understanding is correct, the F2E cards support MACsec but there is no software support yet. According to Cisco this support will be released Q4 2013.  If I am wrong about this please correct me!
In any case, Does anyone have a work around to provide encryption until this support is available? Is it possible to run MACsec on the M2 cards?  We have 10Gig uplinks so to get full usage out of the links IPsec is unfortunately not an option.  any ideas welcome.
Please remember to select a correct answer and rate helpful posts
Steve Fuller
Level 9
Level 9
Hi Marius,
This is my understanding also. I'm told MACsec will be available on a subset of the ports, specifically ports 41-48, from NX-OS 6.2.
In terms of a workaround until that support is available, I can't find a specific reference relating to when MACsec support was introduced for the N7K-M224XP-23L 10GE I/O module, but the 40GE and 100GE modules had MACsec supported added from NX-OS 6.1(1)
From the Release 6.x of the Cisco Nexus 7000 Series NX-OS Security Configuration Guide:
Table 1 New and Changed Security Features
Cisco TrustSec. Added MACsec support for 40G and 100G M2 Series modules. 6.1(1)
Steve Fuller
Level 9
Level 9
Hi Marius,
Thanks for the reply.
Nice link.  Interesting though.  Says that support for 802.1ae was added in 6.1(1) and newest release is 6.1(4).  Perhaps support is already there?
AH my bad, support for M2 card not F2e...
Correct. MACsec support for the F2E is expected in NX-OS 6.2, while support for the 40G and 100G M2 cards was available since NX-OS 6.1(1). I've not found a specific link detailing exactly when support was added for the 10G M2 module.
