POAP failure
narkalya
I am doing a POAP over DHCP/TFTP server, But when the switch initiate the POAP process i see this below error "
%$ VDC-1 %$ %POAP-2-POAP_INFO: Invalid DHCP OFFER from 0.0.0.0: Missing Script Name"
What is causing this issue ?
6 Replies 6
Rick1776
Level 5
Level 5
Do you have a DHCP server setup? Does the switch have any other configuration on the switch?
Rick1776
Level 5
Level 5
I tried the above link: it talks about the general instructions and i hope i followed them during my setup
Here are the details of my DHCP server:
subnet 10.100.100.0 netmask 255.255.255.0 {
range 10.100.100.11 10.100.100.253;
option domain-name "Domain name";
option domain-name-servers <DNS address>;
option subnet-mask 255.255.255.0;
option routers 10.100.100.1;
option tftp-server-name "<DHCP address>";
host <hostname> {
fixed-address 10.100.100.52;
option host-name "<hostname>";
#option dhcp-client-identifier "\<Serial No>";
#option bootfile-name "poap.py";
What interface do you have the switch connecting to the rest of the network. It should send out the DHCP request out all interface and the mgmt interface.
I see the DHCP offer requests are receives on the DHCP Server, But on the Switch ( 3172 ) side, It gives the above error as "Invalid DHCP OFFER from 0.0.0.0: Missing Script Name" "
dhcpd: DHCPDISCOVER from 2c:33:11:7b:2b:80 via 10.100.100.2
Nov 16 00:18:59 <HOSTNAME> dhcpd: DHCPOFFER on 10.100.100.53 to 2c:33:11:7b:2b:80 via 10.100.100.2
Nov 16 00:19:11 <Hostname> dhcpd: DHCPDISCOVER from 2c:33:11:7b:2b:80 via 10.100.100.2
Nov 16 00:19:11 <Hostname> dhcpd: DHCPOFFER on 10.100.100.53 to 2c:33:11:7b:2b:80 via 10.100.100.2
Nov 16 00:19:12 bgl-vc01-ad dhcpd: DHCPDISCOVER from 2c:33:11:7b:2b:80 via 10.100.100.2
Nov 16 00:19:12 bgl-vc01-ad dhcpd: DHCPOFFER on 10.100.100.53 to 2c:33:11:7b:2b:80 via 10.6.108.2
Nov 16 00:19:24 bgl-vc01-ad dhcpd: DHCPDISCOVER from 2c:33:11:7b:2b:80 via 10.6.108.2
Nov 16 00:19:24 <HOSTNAME> dhcpd: DHCPOFFER on 10.100.100.53 to 2c:33:11:7b:2b:80 via 10.100.100.2
Weird, from what I see it should be working.
