Replace Hyperflex hardware
KG555
We have a 3 node hyperflex cluster using HX240C-M4SX nonflash nodes which we will be replacing the nodes with HX220C M5 ALL FLASH NODES. I've googled this but haven't really found any information about this topic. Is it as simple as setting EVC and taking the nodes out 1 at a time and adding the new hardware? Anyone done this or can point me to some documented scenarios for this type of replacement? Thanks.
Kirk J
All flash and hybrid nodes cannot be intermixed in same cluster.
You will need to build up the 2nd all flash cluster, and then vmotion&storage vmotion your guestVMs over to the new cluster.
Kirk...
