Setting Jumbo frame on Nexus 7K vPC
pfillips11
May I know if setting Jumbo frame on a 7K vPC a disruptive process? As we need to make the changes on individual port-channel on switches in vPC peer, I am wondering how Nexus will behave while it has different configuration on the port-channels on two switches.
Thank you.
jdewberr-bt
Hi pfillips11,
Here's the CCO link for setting up Jumbo Frames on the Nexus7000 box:
http://www.cisco.com/en/US/products/ps9670/products_configuration_example09186a0080b44116.shtml
I don't think you'd run into any issues or problems.  In this case you're telling the supervisor to program the hardware to pass a jumbo frame of the size you chose.
What kind of business are you doing with your Nexus7000 boxes?  Is it a 24x7 can't take ten seconds of down time scenario?
JD
