STK-RACK-DINRAIL
felix-girard
Looking for the datasheet and step file (3D drawing) of this part : STK-RACK-DINRAIL
I need to provide the datasheet to my client and need the 3D drawing to design the server cabinet.
AshSe
Hello @felix-girard
Here's a summary of the information available for the STK-RACK-DINRAIL datasheet:
  1. General Description: It's a Cisco 19" DIN Rail mounting kit, primarily designed for use with Cisco Industrial Ethernet switches (IE-3000, IE-4000 and IE2000 series). It allows you to securely mount your network equipment in industrial environments.
  2. Features/Specs:
    1. Type: 19 Inch DIN rail mounting kit.
    2. Compatibility: Cisco Industrial Ethernet (IE-3000 and IE-4000), Cisco Industrial Ethernet 2000 Series, Cisco Catalyst IE3400.
    3. Material: Metal.
    4. Color: Grey.
    5. Operating Conditions:
      1. Operating Temperature: 0 - 70°C
      2. Operating Relative Humidity: 10 - 90%
    6. Storage Conditions:
      1. Storage Temperature: 0 - 70°C
      2. Storage Relative Humidity: 10 - 90%
    7. Dimensions & Weight:
      1. Rack Size: 19" (48.3 cm)
      2. Net Weight: 2.1 kg
      3. Gross Weight (packaged): 2.2 kg
  3. Vendor Information:
    1. Brand: Cisco
    2. Warranty: 1 Year (some vendors may offer different warranties, e.g., 365 days for refurbished units)
  4. Where to Find the Datasheet: You may be able to download it from Router-Switch.com.
Hope This Helps!!!
AshSe
Community Etiquette:
  1. Insert photos/images inline - don't attach.
  1. Always mark helpful and correct answers, it helps others find what they need.
  1. For a prompt reply, kindly tag @name. An email will be automatically sent to the member.
