stp, bpdu
kamtarias
Beginner
Beginner
Hi Guys,
Root bridge has all ports as DP. Root bridge send BDPU across DP. JUst want to know if there are multiple DP port on Root Bridge, which DP port it will use to send BPDU.
Zaid Abuali
Hello
Root bridge will send BPDUs across all its DP ports. following links might be useful for you:
http://www.cisco.com/c/en/us/support/docs/lan-switching/spanning-tree-protocol/24062-146.html
https://supportforums.cisco.com/discussion/11061531/stp-root-port-vs-designated-port
Hope this helps
Best Regards,
Zaid
