UCS Blade Failure re-acknowledge Slot
WEI CHENG CHEN
I hava a problem about UCS Blade re-acknowledging.
I had the problem blade to decommission, and replace the same model blade.
But when I insert the Blade, but it still show Needs Resoulation
And I Click e-acknowledge , it show "failure reacknowledge Slot x. Cause child mgmtcontroller [sys/chassis-x/blade-x/mgmt|mgmt](0xa794e08a)
 of computrBlade [sys/chassis-x/blade-x] is already attached [sys/chassis-x/blade-x/mgmt|mgmt|0xa794e08a]..
If anyone had encountered the same problem ?
Thanks a lot.
fly
Level 2
Level 2
I have same problem.
I replace motherboard of blade , and re insert to same slot.
but I can't re-acknowledge the blade , can't get blade online .
please see attach pic
how did you solve the problem?
thank you
Tom
