Unable to Use "event interface" in EEM on Nexus 9000 with NX-OS 10.3
emmanuel-roger
Hello Cisco Community,
We are experiencing an issue with our Nexus 9000 switches where we are unable to use the "event interface" command as part of Embedded Event Manager (EEM). Here are the details of our setup:
Device Details:
c1-ac5-l7# sh version
Cisco Nexus Operating System (NX-OS) Software
TAC support: http://www.cisco.com/tac
Copyright (C) 2002-2024, Cisco and/or its affiliates.
All rights reserved.
The copyrights to certain works contained in this software are
owned by other third parties and used and distributed under their own
licenses, such as open source.  This software is provided "as is," and unless
otherwise stated, there is no warranty, express or implied, including but not
limited to warranties of merchantability and fitness for a particular purpose.
Certain components of this software are licensed under
the GNU General Public License (GPL) version 2.0 or
GNU General Public License (GPL) version 3.0  or the GNU
Lesser General Public License (LGPL) Version 2.1 or
Lesser General Public License (LGPL) Version 2.0.
A copy of each such license is available at
http://www.opensource.org/licenses/gpl-2.0.php and
http://opensource.org/licenses/gpl-3.0.html and
http://www.opensource.org/licenses/lgpl-2.1.php and
http://www.gnu.org/licenses/old-licenses/library.txt.
Software
  BIOS: version 01.09
  NXOS: version 10.3(5) [Maintenance Release]
  Host NXOS: version 10.3(5)
  BIOS compile time:  10/08/2023
  NXOS image file is: bootflash:///nxos64-cs.10.3.5.M.bin
  NXOS compile time:  4/30/2024 12:00:00 [05/08/2024 09:39:13]
  NXOS boot mode: LXC
Hardware
  cisco Nexus9000 C93180YC-FX3 Chassis
  Intel(R) Xeon(R) CPU D-1526 @ 1.80GHz with 32802764 kB of memory.
  Processor Board ID FDO27131Y5L
  Device name: c1-ac5-l7
  bootflash:  115805708 kB
Kernel uptime is 20 day(s), 0 hour(s), 18 minute(s), 15 second(s)
Last reset at 923509 usecs after Thu Jun 27 08:36:10 2024
  Reason: Reset due to upgrade
  System version: 10.2(7)
  Service:
plugin
  Core Plugin, Ethernet Plugin
Active Package(s):
Issue Description:
According to the Cisco Documentation, the "event interface" command should be available in EEM after enabling the evmed feature.
We have already enabled the evmed feature as follows:
c1-ac5-l7# sh run | i evmed
feature evmed
However, the command is not available:
c1-ac5-l7# conf t
Enter configuration commands, one per line. End with CNTL/Z.
c1-ac5-l7(config)# event manager applet test
c1-ac5-l7(config-applet)# event ?
  cli                 Create a cli event specification
  counter             Create a counter event
  fanabsent           Create fanabsent event specification
  fanbad              Create fanbad event specification
  gold                Create a 'Diagnostic' event specification
  internal-link-flap  Create a 'internal-link-flap' event specification
  memory              Create memory thresholds event specification
  module              Create a 'module' event specification
  module-failure      Create a 'module-failure' event specification
  neighbor-discovery  Show CDP new neighbors
  none                Manually run policy event with none
  oir                 Create Online-Insertion-Removal event specification
  policy-default      Use the event in the system policy being overridden
  poweroverbudget     Create poweroverbudget event specification
  snmp                Create a 'snmp' event specification.
  storm-control       Create a storm control event specification
  syslog              Create a syslog event specification
  sysmgr              System manager related events
  tag                 Event tag identifier
  temperature         Create temperature event specification
  test                Create a 'test' event specification
  timer               Create a timer event specification
  track               Create a 'track' event specification
Could someone help us understand why the "event interface" command is not available in our setup? Any guidance or suggestions would be greatly appreciated.
Thank you!
0 Replies 0
