VLAN limitations with OTV on ASR
pkemp
Hello.
We're relocating a data centre and potentially a large number of VLANs need to be spanned. My ASR has accepted "service instance 1 ethernet" to "service instance 4000 ethernet" commands. But is there a practical limit to the number of VLANs I should be configuring on the ASR using OTV.
Peter
5 Replies 5
Rick1776
Level 5
Level 5
What model of ASR are you referring to?
The router is an ASR 1001-HX (x2).
I see there are no limitations documented. But each ethernet service instance presumably uses a PVST. Could that be a limitation? MST would probably avoid that.
Peter
I don’t believe so, as you can go up 4095 if need be, but I would never push that limit I would break up large amounts if vlans between AED.
How many vlans are we talking about?
What is your ultimate goal to vmotion servers over?
