VPC and STP issue
mahmoud.zakaria
while being on my Core1 Nexus 7000 i think i typed  ‘spanning-tree port type edge default’ then  ‘no spanning-tree port type edge default’
so i think the VPC got affected and now there is no redundancy between core 1 and core2. the whole network now is working on Core 2
thats is part of #show vpc
vPC Peer-link status
id Port Status Active vlans
1 Po2 up 1,5-7,11,14-15,17-25,27-28,30-39,42-44,48-56,60-61
,66,70-71,77-78,82,85,87-88,90-94,99,101,114-123,1
26-128,130-154,158-160,200-202,250-252,300-307,310
,400-419,500,666,993,2001-2012,2099,2102
vPC status
id Port Status Consistency Reason Active vlans
103 Po103 down* failed Global compat check failed -
104 Po104 down* failed Global compat check failed -
105 Po105 down* failed Global compat check failed -
106 Po106 down* failed Global compat check failed -
201 Po201 down* failed Global compat check failed -
202 Po202 down* failed Global compat check failed -
203 Po203 down* failed Global compat check failed -
204 Po204 down* failed Global compat check failed -
205 Po205 down* failed Global compat check failed -
207 Po207 down* failed Global compat check failed -
208 Po208 down* Not Consistency Check Not -
Applicable Performed
209 Po209 down* failed Global compat check failed -
210 Po210 down* failed Global compat check failed -
211 Po211 down* failed Global compat check failed -
212 Po212 down* failed Global compat check failed -
214 Po214 down* failed Global compat check failed -
215 Po215 down* failed Global compat check failed -
216 Po216 down* failed Global compat check failed -
217 Po217 down* failed Global compat check failed -
218 Po218 down* failed Global compat check failed -
219 Po219 down* failed Global compat check failed -
220 Po220 down* failed Global compat check failed -
221 Po221 down* failed Global compat check failed -
222 Po222 down* failed Global compat check failed -
223 Po223 down* failed Global compat check failed -
224 Po224 down* Not Consistency Check Not -
225 Po225 down* failed Global compat check failed -
226 Po226 down* failed Global compat check failed -
227 Po227 down* Not Consistency Check Not -
please can you help?
0 Replies 0
