07-25-2011 10:12 AM - edited 03-01-2019 06:58 AM
I have an issue with vpc in N5K. I am trying to upgrade the existing 3750 stack router with 2 Nexus 5596 running VPC between them. For the transition I have planned to create a channel between 3750 stack and 5596's. Once this environment is set, my plan is to migrate all the access switches to N5k.
The issue is when I connect the 3750 port channel to both N5Ks, all the Vlans on 3750 started to flap. If I connect the port channel to only one N5K everything is normal; but when I connect the port channel to both N5K running VPC, vlans are flapping. Any idea what is going wrong here? Am I missing something?
N5k-1:
vpc domain 2
role priority 1
Bhaskar
07-25-2011 03:21 PM
N5k-1:
vpc domain 2
role priority 1
peer-keepalive destination x source y
N5k-2
vpc domain 2
role priority 1
peer-keepalive destination y source x
You are having role priority with the same value on both switches. Make N5k-2 into a higher number (higher number means less priority). Please test it after you've changed and let me know the result.
HTH,
jerry
08-09-2011 07:33 PM
HI,
I connected the the 3750 to only one N5K on a port channel and managed the migration. The role priority command was not an issue because show VPC indicates that only one device as Primary. Due to the project pressure I had to go ahead with the migration and remove the 3750 from the network which is completed successfully now. Thanks for your inputs.
Bhaskar
