VPC consistency check error
sushilverma05
I have 2 Nexus 5548 switches. I'm facing issues on VPC status down and consistency check not performed.
Below is the output.
vPC status
id     Port        Status Consistency Reason                     Active vlans
216    Po216       down*  Not         Consistency Check Not      -
                          Applicable  Performed
C5548SH02(config-if)# sh vpc brief
Legend:
                (*) - local vPC is down, forwarding via vPC peer-link
vPC domain id                   : 100
Peer status                     : peer adjacency formed ok
vPC keep-alive status           : peer is alive
Configuration consistency status: success
Per-vlan consistency status     : success
Type-2 consistency status       : success
vPC role                        : secondary
Number of vPCs configured       : 93
Peer Gateway                    : Enabled
Peer gateway excluded VLANs     : -
Dual-active excluded VLANs      : -
Graceful Consistency Check      : Enabled
kthned
Level 3
Level 3
Hi Sushil
It seems your vpc peering is perfect but there is some problem with the port channel configuration (po216). It would be nice to share the configuration. The port configuration must be same on both switches part for physcial interface.
sh run interfac po216
sh run inter ethernet "physical port number "
see port configuration on following example
sw01# sh running-config inter po 12
!Command: show running-config interface port-channel12
!Time: Mon Oct  6 12:19:53 2014
version 5.2(1)N1(7)
  description data
  switchport access vlan 2106
  spanning-tree port type edge
  vpc 12
sw02# sh run inter po 12
!Time: Mon Oct  6 12:20:46 2014
version 5.2(1)N1(7)
  description data
  vpc 12
Hi Syed,
see below port-channel config and interface config. both are identical.
N5k-SW1
interface port-channel216
  switchport mode trunk
  spanning-tree port type edge trunk
  vpc 216
interface Ethernet106/1/16
  description SWIGEDPM200
  channel-group 216 mode active
N5K-SW2
  vpc 216
interface Ethernet107/1/16
May be the output of following would help
sh vpc consistency-parameters vpc 216
sh vpc consistency-parameters global
and also the ouput of sh inter po xx from the far end switch ? and if its server than please double check the lacp config are correct etc.
