VxLAN EVPN Testing
cloudlogics
I am new to VxLAN. I am testing VxLAN EVPN in eve-ng following this link
https://www.packetcoders.io/how-to-build-a-nxos-9000v-based-evpn-vxlan-fabric/
I have setup everything and I can see that remote MACs are visible at each VTEP but I can't ping across from end hosts. Not sure what is causing the issue.
Please see attached for details. I am only focusing on connectivity between PC-01 & PC-02.
I have not configured arp suppression but I assume that should not cause any issues.
Ray D
Without going too detailed into troubleshooting, I don't see any RP configuration on NXOS 3,4,5 ? - at least in your output but perhaps you have it in your actual config!
ip pim rp-address 1.2.3.4
Ray.
