VXLAN on Nexus 7k / N7K-F312FQ-25 / NXOS 7.2(0)D1(1)
Surya ARBY
Level 4
Level 4
Hello all.
I'm facing an issue I can't understand. The output of the "show nve peers" is still empty, I don't get the point I missed.
If someone working in consulting teams or at the TAC is reading this thread, your help will be extremeley appreciated, here is the full story
My setup is very simple : 2 N7K connected through ethernet7/8 (L3 with OSPF and PIM) on both sides and loopack interfaces to source the local VTEP.
And attached to each 7k, a 5K just used to simulate a host, trunking on vlan 10 and putting an ip address on interface vlan 10
I configure on the first 7K a vrf and OSPF for the underlay (in this template I don't put the mtu at 1550, but if I do it, it doesn't change anything on the end result)
vrf context underlay
exit
interface ethernet 7/8
no switchport
vrf member underlay
ip address 192.168.100.71/24
no shut
exit
interface loopback 0
vrf member underlay
ip address 192.168.101.71/32
no shut
exit
feature ospf
router ospf OSPF-UNDERLAY
vrf underlay
router-id 0.0.0.1
no shutdown
exit
exit
ip router ospf OSPF-UNDERLAY area 0
exit
interface eth7/8
exit
I do the same on the other 7K, just changing the ip addresses from .71 to .72 and changing the ospf router id. Everything is fine and I get the routes on both sides
N7K-1-pod1# show ip route ospf-OSPF-UNDERLAY vrf underlay
IP Route Table for VRF "underlay"
'*' denotes best ucast next-hop
'**' denotes best mcast next-hop
'[x/y]' denotes [preference/metric]
'%<string>' in via output denotes VRF <string>
192.168.101.72/32, ubest/mbest: 1/0
    *via 192.168.100.72, Eth7/8, [110/2], 04:26:01, ospf-OSPF-UNDERLAY, intra
N7K-1-pod1#
it's fine on the other side
N7K-2-pod2(config)# show ip route ospf-OSPF-UNDERLAY vrf underlay
192.168.101.71/32, ubest/mbest: 1/0
    *via 192.168.100.71, Eth7/8, [110/2], 04:27:08, ospf-OSPF-UNDERLAY, intra
N7K-2-pod2(config)#
then I make a PIM configuration on both side
feature pim
ip pim sparse-mode
exit
interface et7/8
ip pim sparse-mode
exit
ip pim bsr-candidate loopback 0
exit
ip pim rp-candidate loopback 0 group-list 239.1.1.0/24
also it's fine and the rp is elected on one 7K and the other is registered
N7K-2-pod2(config)# show ip pim rp vrf underlay
PIM RP Status Information for VRF "underlay"
BSR: 192.168.101.72*, next Bootstrap message in: 00:00:36,
     priority: 64, hash-length: 30
Auto-RP disabled
BSR RP Candidate policy: None
BSR RP policy: None
Auto-RP Announce policy: None
Auto-RP Discovery policy: None
on the other 7K :
N7K-1-pod1# show ip pim rp vrf underlay
BSR: 192.168.101.72, uptime: 04:29:46, expires: 00:01:17,
Auto-RP disabled
BSR RP policy: None
ok, so at this point to me the underlay is fine. Let's work on the overlay.
On both sides I create a bridge domain, a vni, mapping the vlan (from the 5K) to the VNI, creating the interface nve, and then attaching a service instance on the physical interface connected to each 5K
feature nv overlay
feature vni
vni 5010
exit
system bridge-domain 1000-1999
bridge-domain 1010
member vni 5010
exit
encapsulation profile vni vlan10-vni5010
dot1q 10 vni 5010
exit
int nve 1
source-interface loopback 0
no shut
member vni 5010 mcast-group 239.1.1.10
exit
interface eth7/1
no switchport
no shut
service instance 1 vni
encapsulation profile vlan10-vni5010 default
no shut
exit
I do the same on the other 7K, but on this one the downstream 5K is connected on eth7/2 instead of e7/1
so, on both 7K the mapping of the vni with the nve seems to be ok
N7K-1-pod1# show nve vni
Codes: CP - Control Plane        DP - Data Plane
       UC - Unconfigured         SA - Suppress ARP
Interface VNI      Multicast-group   State Mode Type [BD/VRF]      Flags
nve1      5010     239.1.1.10        Up    DP   L2 [1010]
N7K-2-pod2(config)# show nve vni
I also get the correct multicast route on both 7K (239.1.1.10)
N7K-2-pod2(config)# show ip mroute vrf underlay
IP Multicast Routing Table for VRF "underlay"
(*, 232.0.0.0/8), uptime: 04:56:14, pim ip
  Incoming interface: Null, RPF nbr: 0.0.0.0
  Outgoing interface list: (count: 0)
(*, 239.1.1.10/32), uptime: 04:54:17, nve ip pim
  Outgoing interface list: (count: 1)
    nve1, uptime: 04:54:17, nve
(192.168.101.72/32, 239.1.1.10/32), uptime: 04:54:17, nve mrib ip pim
  Incoming interface: loopback0, RPF nbr: 192.168.101.72
N7K-1-pod1# show ip mroute vrf underlay
(*, 232.0.0.0/8), uptime: 04:55:52, pim ip
(*, 239.1.1.10/32), uptime: 04:54:24, nve ip pim
    nve1, uptime: 04:54:24, nve
(192.168.101.71/32, 239.1.1.10/32), uptime: 04:54:24, nve mrib ip pim
  Incoming interface: loopback0, RPF nbr: 192.168.101.71
on both 7k, the nve interface is up and seems to be ok
N7K-1-pod1# show nve interface
Interface: nve1, State: Up, encapsulation: VXLAN
 VPC Capability: VPC-VIP-Only [not-notified]
 Local Router MAC: f025.72a8.bf42
 Host Learning Mode: Data-Plane
 Source-Interface: loopback0 (primary: 192.168.101.71, secondary: 0.0.0.0)
N7K-2-pod2(config)# show nve interface
 Local Router MAC: b414.89dc.7a42
 Source-Interface: loopback0 (primary: 192.168.101.72, secondary: 0.0.0.0)
let's check both service instances on physical interfaces
N7K-2-pod2(config)# show service instance vni detail
VSI: VSI-Ethernet7/2.1
If-index: 0x35301001
Admin Status: Up
Oper Status: Up
Auto-configuration Mode: No
  dot1q 10 vni 5010
Dot1q   VNI     BD
10      5010    1010
N7K-1-pod1# show service instance vni detail
VSI: VSI-Ethernet7/1.1
If-index: 0x35300001
Admin Status: Up
Oper Status: Up
  dot1q 10 vni 5010
Dot1q   VNI     BD
10      5010    1010
everything is fine, admin up, operationnal state up
let's check the bridge domain
N7K-1-pod1# show bridge-domain 1010
Bridge-domain 1010  (2 ports in all)
Name:: Bridge-Domain1010
 Administrative State: UP               Operational State: UP
        vni5010
        nve1
        VSI-Eth7/1.1
N7K-2-pod2(config)# show bridge-domain 1010
        vni5010
        nve1
        VSI-Eth7/2.1
to me it looks ok.
if I do a ping bewteen my 2 5K (same subnet, same vlan 10 of course) through the vxlan overlay, it doesn't work. WTF ? Let's do the final check
N7K-2-pod2(config)# show nve peers
N7K-2-pod2(config)#
For some reason the show nve peers remains silent, what did I miss ?
Hi Surya
Good to know, its working now. Just to let you know, it is recommended to use static RP with VxLAN than compared to BSR, specially when you require Anycast RP's.
Regarding your other point, i think VxLAN EVPN is much simpler and scalable as it provides control plane learning mechanism and auto-discovery of your vteps.
Hope this info helps.
--Vinit
Vinit Jain
Couple of questions here:
1. any reason you are using a VRF on the underlay? Can you try configuring VxLAN setup with underlay in global routing table just to keep things simple.
2. When you initiate a ping from your N5k, do you see the OIL populated in the show ip mroute output. Currently, i see the S, G entry with no OIL.
Finally, Any reason why you are configuring F&L method and not EVPN (control-plane learning) method?
--Vinit
hello
1 - bgp evpnis too complex just for testing purpose :)
2 - I never see any OIL whatever I do :(
just after writing this message, now it works.
I switched from a BSR config to a static RP and now it works
Hi Surya
--Vinit
