Why configuring clock using clock set command is not accepted in nexus 7k?
dorsia
I have a message like this:
Admin-CORE1_VDC# clock set 15:26:00 7 december 2014
Setting clock from CLI is not allowed in this VDC.
Use the following config command to use the "clock set" command.
clock protocol none vdc <vdc_id>
If I issue that command the message shows like this:
Admin-CORE1_VDC# clock protocol none vdc 2
% Invalid command at '^' marker.
Admin-CORE1_VDC# conf t
Enter configuration commands, one per line.  End with CNTL/Z.
Admin-CORE1_VDC(config)# clock protocol none vdc 2
Pleas advice:
Dani
ashfaq82
You need to select the protocol as none if you are not using NTP or PTP in your environment. This will allow you to manually configure the time on you device.
NX-1(config)# clock protocol none
NX-1(config)# clock set 09:14:00 04 May 2021
Tue May 4 09:14:00 EST 2021
Time source is Hardware Calendar
svalera
i had the same problem, i solved it in the following way
323_LAN_TELCO_CREC_BORDER2# sh clock
15:30:01.660 UTC Fri Mar 14 2025
Time source is NTP
323_LAN_TELCO_CREC_BORDER2# clock set 09:30:30 14 March 2025
Resolved
323_LAN_TELCO_CREC_BORDER2(config)# clock protocol none
323_LAN_TELCO_CREC_BORDER2(config)# clock set 09:41:30 14 March 2025
Fri Mar 14 09:41:30 UTC 2025
09:41:36.118 UTC Fri Mar 14 2025
323_LAN_TELCO_CREC_BORDER2# conf t
323_LAN_TELCO_CREC_BORDER2(config)# clock protocol ntp vdc 1
15:44:35.375 UTC Fri Mar 14 2025
Time source is NTP
323_LAN_TELCO_CREC_BORDER2(config)# clock timezone GMT -6 -00
323_LAN_TELCO_CREC_BORDER2(config)# do sh cloc
09:46:12.687 GMT Fri Mar 14 2025
Time source is NTP
Saludos
