08-17-2017 06:50 AM - edited 03-03-2019 08:37 AM
I bought this 3560 cisco switch but when I turn it on all I get is a blinking light on SYST. Check here and there was told this switch got no firmware.
So i jumped onto cisco site to see if I can download the firmware but here I get all kinds of cisco switches for 3560 have no idea which one is compatible with mine as I have a 3560 series PoE-24 but cannot find this on cisco site.
I am also using Putty to try and install the firmware.
I have attache a picture of my switch model
Also I know I may need help in choosing the correct firmware, if there is anyone who can help me I will really appreciate.
08-17-2017 09:14 AM
Hi 3560 are eol there downloads have been removed from the website as there not supported anymore
you may find them on other websites if you search but first check that its definitely not there
is the device in mode switch: when you console in via putty or what does it show you
follow these steps and if there successful when in switch: mode then type boot
- switch: dir flash: Directory of flash:/ 2 -rwx 5 <date> private-config.text 3 -rwx 110 <date> info 4 -rwx 976 <date> vlan.dat 6 -rwx 286 <date> env_vars 26 -rwx 1592 <date> config.text 8 drwx 1088 <date> html 19 -rwx 110 <date> info.ver 4393472 bytes available (3347968 bytes used) switch: !--- No Cisco IOS images or image directories exist in Flash.
08-17-2017 09:38 AM
thanks for that response so when I try to run the flash_init command it say flash is already initializing and when I run the load_helper command I get unkown cmd load
Also when i run the third command switch: dir flash: Directory of flash: I get this message below
15997952 bytes available (1024 bytes used)
unable to stat Directory/: no such device
unable to stat of/: no such device
switch:
not sure if I am doing it correct and when I hit boot this is what I get
switch: boot
Loading "flash:/c3560-ipbasek9-mz.122-55.SE9/c3560-ipbasek9-mz.122-55.SE9.bin"...flash:/c3560-ipbasek9-mz.122-55.SE9/c3560-ipbasek9-mz.122-55.SE9.bin: no such file or directory
Error loading "flash:/c3560-ipbasek9-mz.122-55.SE9/c3560-ipbasek9-mz.122-55.SE9.bin"
Interrupt within 5 seconds to abort boot process.
Boot process failed...
please help or do I need to get a new switch
08-21-2017 06:01 PM - edited 08-21-2017 06:05 PM
In order to upgrade a device you must consider the following:
- Available space on the device, you could execute show flash (it could vary sometimes it could be saved on the bootflash, slot, etc)
In some situations you must delete the current image (NOTE: Don't reload the device once the image is removed)
- Connectivity between the Device's IP and the Server or computer FTP.
- Get a backup.
- Have the proper image to upgrade.
These links could be useful:
https://www.cisco.com/c/en/us/support/docs/switches/catalyst-3550-series-switches/41541-190.html
https://www.packet6.com/how-to-upgrade-the-ios-of-a-cisco-switch/
Using a TAR image: https://www.youtube.com/watch?v=utSbMinOID4
if you have a Cisco contract, you can download the image from here, just select the proper model, it can be displayed rear of the device.
https://software.cisco.com/download/navigator.html?mdfid=278542537
Hope it is useful
