03-05-2006 06:25 PM - edited 03-03-2019 02:08 AM
Hello.
We have 4006 switch with engine2 & 4232-l3.
I'll replace engine2 with engine V.
Question : Could I used 4232-l3 interface port(32port fastethernet) with engine V.
Thank you.
03-05-2006 06:46 PM
The Supervisor Engine V does not support the WS-X4232-L3, as per:
Hope that helps - pls rate the post if it does.
Paresh
03-05-2006 08:16 PM
so much thank you.
one more question : how about engine iv(4515) ?.
I think same that... but i can't find document about 4515 and 4232-l3.
03-05-2006 09:12 PM
I find document about 4232-l3 and engine
There is no support, however, for the router module when you use it in conjunction with Supervisor Engine 2+, 3, 4, or 5
thank you.
