4500 Aggregate policers and Per-Port Per-VLAN QoS
Jan Jong
I want to limit the aggregate traffic of multiple VLANs on a trunk using an aggregate policer. I also need Per-Port Per-VLAN QoS for other VLANs on the same trunk.
To cut a long story short, will the example config below work?
qos aggregate-policer pol_aggr_10Mbit 10m 12.5k conform-action transmit exceed-action drop
policy-map Aggr_10Mbit
class class-default
police aggregate pol_aggr_10Mbit
policy-map Limit_10M
class class-default
police 10m 12.5k conform-action transmit exceed-action drop
interface GigabitEthernetx/y
switchport mode trunk
! Aggregate 10Mbit VLANs
vlan-range 208, 316, 909
service-policy output Aggr_10Mbit
! 10 Mbit VLANs
vlan range 20, 50-100
service-policy output Limit_10M
Regards, Jan
mchin345
Level 6
Level 6
Your config looks good . Actually Per-port per-VLAN QoS (PVQoS) offers differentiated quality-of-services to individual VLANs on a trunk port. It enables service providers to rate limit individual VLAN-based services on each trunk port to a business or a residence. In an enterprise Voice-over-IP environment, it can be used to rate limit voice VLAN even if an attacker impersonates an IP phone. A per-port per-VLAN service policy can be separately applied to either ingress or egress traffic.
