4500 - DHCP snooping and Netware SLP problem
j.volf
Hi all,
we try to implement DHCP snooping with Source Guard on Cat 4500. These Cat 4500 are used as workgroup switches with 6513 in the core. Novell Netware 6.0 witch SLP configured on it acts as a DHCP server (connected to Cat 6513). It works OK without DHCP snooping. At the time we have started DHCP snooping clients haven't received Option 78 and 79 (SLP information) from Netware server. All other information from DHCP server is OK.
With DHCP snooping turned off is everything OK with the same configuration.
IOS 12.2(20)EWA
Any idea ?
mchin345
Level 6
Level 6
When IP source guard is enabled in IP and Mac filtering mode, and DHCP snooping option 82 is disabled, the switch can't locate client host port to forward DHCP server reply. The DHCP reply is dropped and therefore client can't obtain an IP address.
In general, IP source guard can't be set to IP and Mac filtering mode in a network where DHCP server doesn't support DHCP option 82.
For more detailed information about DHCP Server can be found from the link below:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios120/120newft/120t/120t1/easyip2.htm
Configuration -
6513 in the core (VLAN routing)
interface Vlan32
description 4500_FD1_LEFT
ip address xxxxxxxx
ip helper-address xxxxx
no ip redirects
ip dhcp relay information trusted
4500 as a workgroup switch (without routing)
ip dhcp snooping vlan 1-100
ip dhcp snooping database tftp://xxx/4506_FD1.txt
interface GigabitEthernet1/1 (trunk to 6513)
switchport mode trunk
ip dhcp snooping trust
interface GigabitEthernet2/3 (testing interface)
switchport access vlan 32
switchport mode access
spanning-tree portfast
ip verify source vlan dhcp-snooping
When DHCP snooping is disabled client receive all DHCP information including Netware related info (options 78 & 79)
When I enable DHCP snooping client receive IP address, Mask, Gateway, DNS correctly. Information about Netware tree (78) and services (79) are blocked. I think, that there is some problem with propagation of follow-up DHCPINFORM packet.
DHCP server is located on Netware server with support for option 82. If there is a problem with option 82 that must be also visible with DHCP snooping turned off.
Maybe problem in my advisement ?
I post this problem on TAC through distributor without resolving in last 5 days (they say "working on it").
Any recommendation is welcome.
Jiri
