857 ADSL Problems
jrofarrell
I have recently purchased 2 857W boxes and no matter what I try I cannot get the ATM0(ADSL) interface to connect. The site I am testing from currently has an 837 which works fine (2Mb down/512Kb Up, line in the UK).
I have tried various ios images from the first to the most current and the same problem remains.
Any help/ideas would be much appreciated
Thanks in advance
JOF
Output of debug atm events;
*Mar 1 01:07:26.171: DSL: Send ADSL_OPEN command.
*Mar 1 01:07:26.171: DSL(ATM0): Using subfunction 0x0
*Mar 1 01:07:26.171: LOCAL:Max noise margin for power cutoff 31
*Mar 1 01:07:26.171: DSL(ATM0): Sent command 0x3
*Mar 1 01:07:28.671: DSL(ATM0): 1: Modem state = 0x9
*Mar 1 01:07:31.171: DSL(ATM0): 2: Modem state = 0x10
*Mar 1 01:07:33.671: DSL(ATM0): 3: Modem state = 0x10
*Mar 1 01:07:36.171: DSL(ATM0): 4: Modem state = 0x10
*Mar 1 01:07:38.671: DSL(ATM0): 5: Modem state = 0x10
*Mar 1 01:07:40.623: DSL: Received response: 0x22
*Mar 1 01:07:40.623: DSL: Open failed: Error in early non-CRC message or in fir
st CRC-covered message -- retrying
*Mar 1 01:07:40.623: sleep 5 seconds
For some reason the DSLAM returns an 0x22 code during the connection. I assume the DSLAM has sent the code as a 0x10 code has come back.
The Config
Building configuration...
Current configuration : 2947 bytes
version 12.3
no service pad
hostname yourname
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
username xxx privilege 15 secret xxxx
no aaa new-model
ip subnet-zero
ip dhcp excluded-address 10.10.10.1
ip dhcp pool sdm-pool
import all
network 10.10.10.0 255.255.255.248
default-router 10.10.10.1
lease 0 2
ip cef
no ip domain lookup
ip domain name yourdomain.com
no ftp-server write-enable
crypto pki trustpoint TP-self-signed-720084316
subject-name cn=IOS-Self-Signed-Certificate-720084316
revocation-check none
rsakeypair TP-self-signed-720084316
interface ATM0
no ip address
no ip mroute-cache
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/38
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface FastEthernet0
no ip address
shutdown
no cdp enable
interface FastEthernet1
no ip address
shutdown
no cdp enable
interface FastEthernet2
no ip address
shutdown
no cdp enable
interface FastEthernet3
no ip address
shutdown
no cdp enable
interface Dot11Radio0
no ip address
shutdown
speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0 48.0
54.0
station-role root
no cdp enable
interface Vlan1
description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$
ip address 10.10.10.1 255.255.255.248
ip tcp adjust-mss 1452
interface Dialer1
ip address negotiated
encapsulation ppp
dialer pool 1
dialer-group 1
no cdp enable
ppp authentication chap
ppp chap hostname abc@abc.com
ppp chap password xxxxxxxxxxxxxxxxxxxxxxxxxx
hold-queue 224 in
ip classless
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 600 life 86400 requests 10000
no cdp run
control-plane
line con 0
login local
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet ssh
scheduler max-task-time 5000
end
4nchristie
We got this sorted (with help from Cisco TAC):
On the 877/1801 (presumably same on 857), we had to say:
int atm0
dsl operating-mode ansi-dmt
instead of:
We also need to do a shutdown/no shutdown and sometimes pull the DSL cable if changing this setting.
We're trying to get details from BT of the DSLAM make and firmware version, on the lines where we've seen this problem, to feedback to Cisco.
Regards, Neil, Internet for Business.
smalkeric
Level 6
Level 6
This error is usually related hardware problem and Please verify the encapsulation with the Service Provider as well.
http://www.cisco.com/en/US/products/hw/routers/ps380/products_tech_note09186a0080093e48.shtml
4nchristie
int atm0
instead of:
Thanks for that;
fixed the problem.
James O'Farrell
dp_durham1
Had the same issue. Change the dsl operating mode to dsl operating-mode ansi-dmt no auto.
This should get you working.
Darren
