ADSL on an 837- Using NetFlow
5ncamden
We are running NetFlow switching on many sites and links (serial, Frame) and it is all fine- 2 way traffic flows showing up great. Can't seem to get 2-way stats from ADSL lines though. I have tried putting the ip route-cache flow command on the dialer and the serial infterface, but I still only get one way traffic. (Also got the command on the Ethernet)... Any ideas if this is possible ?? We are using 12.2(8) IOS, then Crannog NetFlow Monitor to view the output.
umedryk
Level 5
Level 5
Hi, please check the release notes of the mentioned IOS.
You may go to www.cisco.com/univercd , select appropriate version from Cisco IOS Software and check the release notes.
