ATM OC-3 Network Module not recognized on 3620 router
laurencem
We have a 3620 router with a fast ethernet card.
the IOS version is 12.0(13)
When we add the ATM OC3 Network Module NM-1A-OC3MM,
our router doesn't recognize it.
The EN Led flashes once and then goes off.
We have tried 2 different cards with 2 different
3620 routers.
The mother board and the PCMCIA controller or compatible with this module.
So we think the hardware is not faulty.
We think our IOS may not be right.
Any suggestion ...
Laurence
svermill
Level 4
Level 4
You will need new IOS. Here is the link to the Hardware/Software Compatibility Matrix:
http://www.cisco.com/cgi-bin/front.x/Support/HWSWmatrix/hwswmatrix.cgi
You'll need a plus version of IOS
Thank you.
Now I need to find the good version.
