basic firewall connection error
aysemsude
Visitor
Hi ,
I am a beginner and trying to build a simple network with a firewall. But ı cannot send icmp packets between to networks through the firewall.  Any help will be appreciated, thank you.Ekran görüntüsü.pngss.pngss1.png
6 Replies 6
Hi @aysemsude
 As you are using the same security level on both interface, the firewall on this case is most like a router. What you can be missing is routes on the router and or in the firewall.
 If you run a tracert from PC0 towards PC1 where it stops?
Thank you for your reply. I get this screen.
Can you share the pkt file here? You need to zip the file first.
Alternativelly, you can share the router config and the firewall config. The whole config please
Here is the file thank you for the reply
Martin L
You can attach PT file here but it must be in a zip format;
Also check CLN community PT and CCNA forums at
https://learningnetwork.cisco.com/s/communities
https://learningnetwork.cisco.com/s/topic/0TO3i0000008jYHGAY/ccna-certification-community
https://learningnetwork.cisco.com/s/topic/0TO6e000000WEorGAG/packet-tracer
Regards, ML
**Please Rate All Helpful Responses **
Here is the file.Thank you for the reply
