Hi all,
I would like to know how to configure an Active Passive failover solution using BGP + HSRP(with ip sla to track line up/down) in 2x Cisco CPE.
For example the IP assignment as below:
Primary Router:-
WAN IP: 10.10.10.2/30; GW: 10.10.10.1/30
LAN IP(Primary): 172.16.1.1/24
LAN IP(Secondary): 12.12.12.1/24
HSRP Virtual IP: 172.16.1.3
Backup Router:-
WAN IP: 10.10.10.6/30; GW: 10.10.10.5/30
LAN IP(Primary): 172.16.1.2/24
LAN IP(Secondary): 12.12.12.2/24
BGP info:
AS No: 12345
Remote-AS: 67890
Password: abcde
There will be an unmanaged switch connect to these 2 routers LAN interface and my PC will connect to this switch to perform failover test.
Appreciate if anyone can share his/her knowledge and guide me on this.
Let me know if the details above is insufficient.
Thanks.
CS
