C9300 - Problems with executing TCL script using Python "cli" library
malyj
Hello everyone!
I am trying to execute TCL WoL script using Python3 and "cli" library, that is running inside Guestshell on Catalyst 9300 IOS XE.
In my running-config I have specified:
'scripting tcl init flash:wol.tcl'
so after executing "tclsh" I can run "WakeOnLan xxx.xxx.xxx.xxx xxxxxxxxxxxx" and it sends MagicPacket.
But here is the problem. When I start Python console using "guestshell run python3", then "import cli" to import library and finally command 'cli.cli("tclsh ; WakeOnLan xxx.xxx.xxx.xxx xxxxxxxxxxxx") it show this error message:
Spoiler
Traceback (most recent call last):
  File "/usr/lib/python3.6/site-packages/cli/__init__.py", line 340, in cli
    subprocess.check_output(cmdline, stderr=subprocess.STDOUT, shell=True)
  File "/usr/lib64/python3.6/subprocess.py", line 356, in check_output
    **kwargs).stdout
  File "/usr/lib64/python3.6/subprocess.py", line 438, in run
    output=stdout, stderr=stderr)
subprocess.CalledProcessError: Command 'iosp_client -om 3 -o /tmp/.iosp_2023_06_08_09_32_
09_233542_735378408.output -i /tmp/.iosp_2023_06_08_09_32_09_233542_735378408.cmd' return
ed non-zero exit status 1.
During handling of the above exception, another exception occurred:
  File "<stdin>", line 1, in <module>
  File "/usr/lib/python3.6/site-packages/cli/__init__.py", line 350, in cli
    raise IOSPCLIError
cli.IOSPCLIError: CLI syntax error or execution Failure
For me it seems like that TCL init script won't load when "tclsh" is executed using Python cli command.
I would be grateful for any ideas on how to solve this problem. Thanks!
0 Replies 0
