Can I mirror a serial interface....
UN-FALD
Hi..
Is it possible to mirror a WAN interface on the router.Means if the packets are coming on one serial interface can go to another mirrored serial interface at the same time. i need to analyze A WAN link with out putting the analyzer in between the WAN link. So i am thinking to mirror the another serial interface on the same router to see the packets.
Thanks.
SS
Not applicable
No I don't think you can, you have one of two options one you put a splitter on the serial interface then a copy of the feed goes into an adaptor Nai (network associates) do one.
Second mirror the Ethernet port, if it goes into a switch and put a sniffer on the mirror port this will then show you what is passing over the router with source and destination address etc.
