Cannot route 2 Ethernet LAN segments using Cisco 1605R
renan_1980
Why can't I ping computers connected on Ethernet 2 from computers on Ethernet 1.(by the way all computers gateway connected on Ethernet 1 is the ip address of Ethernet 1 port of the router). I dont have any access-list. I just want only to connect the two networks. Also my IOS is c1600-y-mz.120-17. (with 4MB of flash and 8 MB of memory). Here is my configuration:
interface Ethernet0
ip address 172.29.168.6 255.255.255.0
no ip directed-broadcast
interface Ethernet1
ip address 172.29.162.7 255.255.255.0
Hope you can help me,
Renan
lgijssel
Level 9
Level 9
Seems you have a problem with your network, but you do not know where.
Try the following step-by step method:
From the PC on e0, ping to router's e0, if succesfull, ping to e1.
If these are working both, routing for e0 and it's attached PC is working OK.
Then, still from the same node, ping to a PC on e1. If the above works, and this doesn't, the PC on e1 is the cause. Repeat the sequence above for all nodes. When you have a non-working situation you will be able to determine where your problem is coming from.
Goodluck.
I don't know if your probleme has been resolved or not
so if not send me the configuration file and for seen if all command lines are right!!
To All,
Thanks to all, my problem are already solved it is regards to my crosscable. It is been connected to wrong port.
Renan
