Cat2950, LED issue, POST probs
gopal_voip
hi guys
im at the same campus in which i had mylast VTP issue, now teh taste is diff, thius swicth of mine, has falied loopback test, for 1-8 Fasether ports, im attaching the bootsequence.take a look.
teh system led is green , ok, all the other LED are off, the ports are working but LEDs r off, at POST soem LEDs turn amber, soem.
just fill me up..lpsss
Shukky
India.
lgijssel
Level 9
Level 9
This is bad news. This type of failure message is typical for port-hardware malfunction. I sincerely hope that you jave a support contract for this switch because this is the time to make a call. If not, you are on your own.
Leo
hi
even i thought so, just wanted a confirmation.
thanx bro
shukky
India
