Cat3750 Policy Base Routing trouble
raiffeisen-ua
I have Stack with Cisco Catalist 3750
* 1 28 WS-C3750G-24TS 12.2(20) C3750-I5K91-M
2 28 WS-C3750G-24TS 12.2(20)SE C3750-I5K91-M
3 28 WS-C3750G-24TS 12.2(20)SE C3750-I5K91-M
6 26 WS-C3750-24TS 12.2(20)SE C3750-I5K91-M
7 28 WS-C3750G-24TS 12.2(20)SE C3750-I5K91-M
I'm try enable Policy Base Routing, but
UAAC3750(config)#sdm prefer routing-pbr
% Invalid input detected at '^' marker.
and
UAAC3750(config)#sdm prefer extended-match
and
UAAC3750#sh sdm prefer ?
default show default template configuration
routing show routing template configuration
vlan show vlan template configuration
| Output modifiers
<cr>
Why ?
Thanks you.
Vitaliy
do you have ´ip routing´ enabled gobally on your switch ?
Georg
l-gu
Maybe you try
UAAC 3750(config)# sdm prefer ?
I think this version of 3750 doesn't support these two commands.
