03-24-2005 09:26 AM - edited 03-02-2019 10:15 PM
We have some Catalyst 2950T with IOS 12.1(20). We were experiencing problems with Broadcast Storm-Control combined with an assigned IP-ACL on the same interface.
When there was no IP-ACL on the fe-Interface the Broadcast Storm-Control limited the rate of Packets correctly. With an IP-ACL assigned to the Interface the Switch still reported "blocking" in the "show storm-control" command but all packets came through - none was dropped.
This behavior was verified with multiple Switches and multiple Software-Releases.
Has somebody experienced the same problem? I have studied the C2950 Release Notes but I couldn't find any hint about that ...
Thank you very much and best regards,
03-25-2005 03:48 AM
Hello Christian,
interesting...can you post your configuration (the one with the access list applied) ?
GP
03-25-2005 12:05 PM
Thank you for your reply:
This is the configuration with ip acl applied:
interface FastEthernet0/3
description USER
switchport access vlan 10
switchport mode access
switchport port-security
switchport port-security aging time 1
switchport port-security violation restrict
no ip address
ip access-group 101 in
no logging event link-status
service-policy input pmap-udp
storm-control broadcast level 0.01
storm-control multicast level 0.01
spanning-tree portfast
ip dhcp snooping limit rate 20
The ACL was:
access-list 101 deny udp any any eq netbios-ns
access-list 101 deny udp any any eq netbios-dgm
access-list 101 deny tcp any any eq 139
access-list 101 deny tcp any any eq 445
access-list 101 permit ip any any
and this is the working Configuration without the IP-ACL:
description USER
switchport port-security aging type inactivity
(the "switchport port-security aging type inactivity" was added afterwords and had no effect on the problem);
Thank you!
03-25-2005 02:44 PM
for some reason the access list is overriding the storm control settings...can you add the ´log´ keyword to your ´permit ip any any´ statement and check what the access list actually allows through, that is, if there are broadcast or multicast packets allowed and where they come from ?
GP
04-01-2005 10:15 AM
Sorry for the late answer:
I am sorry but i couldn't get any further information because the log keyword seems not to be supported here:
%Error: Access-list with 'log' keyword is not supported on Ethernet Interface.
We tried this behavior now with the latest ED-Release 12.1.22EA4 on the C2950T - it is still the same behavior ...
Here is the Access-List tested with:
and here the IF Config:
interface FastEthernet0/18
description USER
Thank you and best regards,
Christian
04-01-2005 10:33 AM
Something we tried in addition:
The problem also exists with a simple "permit ip any any"ACL oder "permit udp any any" ...
04-29-2005 11:35 AM
Is there any chance to report a Bug to Cisco Systems without having a support-contract?
Thank you & best regards,
